Date/Time: Tue, 01 Apr 2025 22:05:47 +0000
Pulling/Stacking Sums on DOM
View Count: 735
[2022-12-15 17:53:19] |
User558380 - Posts: 40 |
Hi! I've added Bid and Ask Market Depth/Pulling and Stacking columns to my DOM and the sums appear at the top and bottom of those columns. Is there a way I can transfer or overlay those sum totals onto my main graph? Currently I have to scroll to the top or bottom of those columns to see the totals and I'd love to be able to just glance at them without scrolling. Thanks so much.
[2022-12-15 18:05:36] |
Sierra_Chart Engineering - Posts: 19040 |
No that is not supported unless you create a custom study to do this. There are these two ACSIL functions to access to data: double (SCDLLCALL* GetBidMarketDepthStackPullSum)();
double (SCDLLCALL* GetAskMarketDepthStackPullSum)(); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-15 18:05:42
