Date/Time: Tue, 01 Apr 2025 22:04:44 +0000
TPO - Empty Space Between Sessions
View Count: 427
[2022-12-15 16:41:18] |
Benutzer4711 - Posts: 35 |
Hello, any chance to reduce this "empty space" that can be filled with VbP between the TPO sessions? See attached. https://www.sierrachart.com/image.php?Image=1671122408611.png In the TPO documentation, the space seems to be reduced: https://www.sierrachart.com/images/TPOProfileChartZB2TickWithLetters.png THX Date Time Of Last Edit: 2022-12-15 16:42:46
[2022-12-15 18:44:02] |
John - SC Support - Posts: 39080 |
The only thing you can do is to reduce the bar spacing.
[2022-12-15 22:01:40] |
Sierra_Chart Engineering - Posts: 19040 |
We will have a look at this. Can you provide us that chart. Follow these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
