Date/Time: Fri, 18 Apr 2025 19:00:44 +0000
Horizontal Lines Being Erased
View Count: 488
[2022-12-15 16:28:20]
User728373 - Posts: 9
Several times I have drawn horizontal lines for annual, quarterly, monthly and weekly prices. I save them. But eventually Sierra Chart erases them. Obviously, this is is extremely frustrating to me. I have spent dozens of hours repeatedly drawing these horizontal price lines only to log on and see there no longer there. Does anyone else experience this problem? Is there a remedy?
[2022-12-15 18:18:07]
John - SC Support - Posts: 39357
They are not being erased, unless you have specifically erased them. Most likely is that you rolled over the symbol of the chart and did not roll over the drawings symbols. Refer to the following:
Chart Drawing Tools: Showing or Hiding Drawings for Different Symbols
If it is not about rollover, then there is still something occurring that is causing an issue. You can view the drawings in "Tools >> Manage Chart Drawings" and then determine what you need to do to have them showing properly again.
[2022-12-17 17:04:21]
Thank you. I had no idea that the drawings would disappear once the symbol rolled over.
[2023-01-23 03:23:32]
Sierra_Chart Engineering - Posts: 19269
Refer to:
Changing to a New Futures Contract Month: Allowing Lines and Other Chart Drawings From Other Contract Months to Appear on the Current Contract
