Date/Time: Thu, 03 Apr 2025 20:30:17 +0000
request
View Count: 456
[2022-12-15 14:28:50]
User427561 - Posts: 217
how can I add or modify the dropdown menu of the mouse drop dowm list? . e.g. I would like to add the "hand" symbol to the drop down list. is thst possible ?
[2022-12-15 17:30:42]
John - SC Support - Posts: 39147
Select Global Settings >> Customize Chart Shortcut Menu. The options are organized by the order of the pulldown menus across the top (File, Edit, Chart, etc.).
Refer to the following:
Global Settings Menu: Customize Chart Shortcut Menu (Global Settings menu)
[2022-12-29 18:29:32]
following these instrucyions i still cannot find a way to add the hand icon to the mouse drpdown menue. can you help further?thanks
[2022-12-29 18:46:54]
It is in there under that selection (customize chart shortcut list). About halfway down the total list.
As noted above, the items in the list are organized by the order of the pulldown menus from left to right. So the Tools are listed just after the Analysis section (which is very small). You will see the following for the beginning of the tools section -- Tools >> --.
Date Time Of Last Edit: 2022-12-29 18:47:23
