Date/Time: Fri, 04 Apr 2025 04:11:32 +0000
Connection sierra chart par routeur telephonie mobile
View Count: 479
[2022-12-15 00:49:27] |
User741988 - Posts: 14 |
Hello, I trade with the footprint on the NQ and the ES from 10:00 a.m. to 12:00 p.m. CMT on a fixed workstation pc with a fiber internet connection. Before investing in a laptop, I wanted to know if I could trade by connecting via sharing my 4g network connection on my mobile phone. Does this connection system allow you to trade in good conditions? I wanted to get your opinion on this matter. (translated from the original) Bonjour, Je trade avec le footprint sur le nq et l’es de 10h00 à 12h00 CMT sur pc workstation fixe avec connexion internet fibrée. Avant d investir dans un pc portable, je voulais savoir si je pouvais trader en me connectant via le partage de ma connexion du reseau 4g de mon téléphone mobile. Est ce que ce système de connexion permet de trader dans de bonnes conditions ? Je voulais avoir votre avis sur cette question. |
[2022-12-15 15:46:24] |
John - SC Support - Posts: 39148 |
It is not something we would recommend, but it is really a personal choice. And it depends a lot on how good the 4G coverage is what kind of speeds you can get. And you need to compare that with your local Internet provider and how well they do. The 5G cell phone network is much faster and stable and would be more capable for what you are wanting to do. If you really need to use the cell network, then we would highly recommend getting a 5G phone, if it is available in your area. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
