Date/Time: Tue, 01 Apr 2025 22:05:46 +0000
Extension of alert of volume at price
View Count: 456
[2022-12-15 00:16:09]
Ben A - Posts: 123
Is there a way of adding an extension line to a volume at price alert?
For example adding 10 point extension to an alert. If +1000 at price 3950 draws a line at 3960
Thank you for your answer
[2022-12-15 15:39:47]
John - SC Support - Posts: 39080
Extension lines are supported in the Volume at Price Threshold Alert V2 study through the Input for "Draw Extension Lines". Refer to the information here:
[2022-12-16 02:35:20]
Ben A - Posts: 123
Thanks John, What I was trying to do was add a band/extension to this extension line eg +/- 10 points for example if occurs at 3950 draw a line at 3960 10 points away, is this possible? - I tried but was unsuccessful
Thanks again
Date Time Of Last Edit: 2022-12-16 02:36:01
[2022-12-16 03:48:38]
Sierra_Chart Engineering - Posts: 19040
No, you have to modify the study to do what you want.
