Date/Time: Tue, 26 Nov 2024 17:25:57 +0000
Modifying parameters for 3rd-party custom study
View Count: 1007
[2014-05-29 17:18:35] |
User11638 - Posts: 21 |
Hello. I have recently added EminiPlayer's Support/Resistance levels as a custom study. I would like to change the colors of the S/R levels as they display on my chart. I have gone to the custom study section and the settings screen for the studies and found the color definitions however, when I change the colors no impact is made on my chart. Please advise. Thank you. |
[2014-05-29 17:22:47] |
Colors are set through the Subgraphs tab of the Study Settings window: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#TechnicalStudySettingsWindow If you are changing the colors and they do not go into effect, then this means the study is not properly programmed. The developer needs to contact us for help with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-29 17:23:08
