Date/Time: Tue, 26 Nov 2024 17:44:38 +0000
Point of Control and Value Area Extension Line Labels
View Count: 1103
[2014-05-29 16:24:31] |
User98954 - Posts: 2 |
Dear Mr. I'm trying to apply the values of value area and control point on my chart, but I'm not getting it. You guys can help me with this? Best regards |
Untitled.jpg / V - Attached On 2014-05-29 16:23:31 UTC - Size: 319.6 KB - 365 views |
[2014-05-29 16:46:54] |
You first need to set the Value Area and Point of control lines to extend. We have updated the documentation here to explain this: http://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html#POCAndValueAreaExtensionLineLabels Click on the link above and reload the page in your browser to get the updated documentation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-29 17:12:07] |
Perfect! Thank you much! |
