Date/Time: Tue, 01 Apr 2025 22:05:46 +0000
SIm trading
View Count: 510
[2022-12-14 16:16:25] |
coachted - Posts: 386 |
is there a way to create mutliple sim accounts..ie sim 1, sim 2, sim 3???? I am looking to trade specifc setups and want statistics kept seprately by trade setup
[2022-12-14 19:31:42] |
Sierra_Chart Engineering - Posts: 19040 |
Yes absolutely you can use as many simulation accounts as you want. Refer to this setting: Global Trade Settings Windows: Number of Simulation Accounts (Global Settings >> General Trade Settings >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-14 22:54:25] |
can you name the account??? ie can i name sim1 Value fade setup???
[2022-12-15 15:30:03] |
John - SC Support - Posts: 39080 |
You can not name the accounts, they are just "Sim" + number (i.e. Sim1, Sim2, etc.).
