Date/Time: Tue, 01 Apr 2025 22:07:57 +0000
[Programming Help] - Spreadsheet and stop at profit target questions
View Count: 291
[2022-12-14 15:51:51] |
Dean Roberts - Posts: 79 |
Hi Tom and John 2 quick questions please - thank you for your continued support with my questions; 1. If I have 20 different formulas for scalping set ups that should all operate under different circumstances on the same chart - should I set them up as separate SHEETS on the same spreadsheet, rather than having 20 spreadsheets? 2. If I want to cease trading for the day when I hit a target of 60 points - what is the best/simplest way to do this please? I see that Global Profit/Loss options are not reliable - could I add a check in the formula that if a profit cell in spreadsheet is above a certain level then the buy/sell does not get a TRUE.. or could I do a text display for the profit study and add in the formula to say if the text figure is above a figure then the buy/sell does not get a TRUE again? Is there a reliable and simple option to do this? Much appreciated Cad |
