Date/Time: Tue, 01 Apr 2025 22:07:57 +0000
DOM Active Trade Settings
View Count: 428
[2022-12-14 15:04:26] |
countryboy92 - Posts: 91 |
I noticed that if I add a trade after I'm already in a trade, that the DOM show's a separate line for each respective stop and target, but combines the trade entry point line at some average of the multiple entry point prices. Is there a way for the Dom to show a separate line for each trade entry price instead of combining them? Is there also a way to differentiate the Stop and Target for each trade with a number or letter? With multiple trades active at the same time, each stop and entry line show the same information, so I can't tell which is which?
[2022-12-14 18:43:45] |
John - SC Support - Posts: 39080 |
Is there a way for the Dom to show a separate line for each trade entry price instead of combining them? No, refer to:Trading Information Windows: Only Single Consolidated Position Maintained and Displayed per Symbol and Trade Account Is there also a way to differentiate the Stop and Target for each trade with a number or letter? With multiple trades active at the same time, each stop and entry line show the same information, so I can't tell which is which? What you can do is enable the Connecting lines:Global Trade Settings Windows: Order Association Lines (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-15 16:00:19
[2022-12-15 16:00:55] |
Sierra_Chart Engineering - Posts: 19040 |
Post above has been updated with this link: Trading Information Windows: Only Single Consolidated Position Maintained and Displayed per Symbol and Trade Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
