Date/Time: Tue, 01 Apr 2025 22:05:47 +0000
Draw Volume profile not working
View Count: 342
[2022-12-14 13:38:41]
User710679 - Posts: 43
The Draw Volume Profile button is not working, and it does not allow me to manually select an area.
Literally, in your web says "you will need to be on Sierra Chart service package 5 to use this feature" and i have enabled Service Package 10 - Integrated Standard
Do i have to upgrade the package to a higher version in order to use that? I already have service pack 10 but it does not work.
THanks for you help
[2022-12-14 14:53:34]
Sierra_Chart Engineering - Posts: 19040
You do actually need Service Package 11 for this. Since Service Package 11 is equivalent to 5 with the Denali Data Feed.
We have now given you access to service Package 12 at no cost for the next 30 days.
