Date/Time: Tue, 26 Nov 2024 17:35:41 +0000
Can not move Order position line
View Count: 2487
[2014-05-29 15:58:21]
User53601 - Posts: 105
Could you help with this please:
I put an order on the chart, afterwards I want to move the position to other price.
However it is not possible, the position line stays at the same price.
On other chart/market I can trade normally, I can move the order position line.
Few days ago it worked ok.
Thank you
Date Time Of Last Edit: 2014-05-29 15:59:12
[2014-05-29 16:29:40]
There is a difference between an Order and a Position. A Position line cannot be moved.
Are you referring to a working order?
[2014-05-29 16:31:22]
yes, I mean working order.
[2014-05-29 16:47:53]
Do you have Trade >> Chart Trade Mode On enabled for the chart?
[2014-05-29 16:57:11]
yes I have. attached please find the trade setting.
imageWorking order - Trade menu.png / V - Attached On 2014-05-29 16:56:46 UTC - Size: 39.5 KB - 396 views
[2014-05-29 17:20:54]
Provide an image of the chart showing the order you are trying to move, by following these instructions:
https://www.sierrachart.com/index.php?l=PostingInformation.php#Image
[2014-05-29 18:05:35]
thank you, I have solved the problem.
The issue was, I have not had the setup for broker connection.
Jaro
