Date/Time: Sat, 30 Nov 2024 02:55:08 +0000
Left Side Scale Bug
View Count: 356
[2022-12-14 13:20:36] |
User177741 - Posts: 48 |
When using Left Side Scale and disabling the Right Side Scale... there are 2 bugs: 1. The left side scale has no context menu when you right click... so we cannot reset scale etc. 2. There is no way to resize the chart panes |
[2022-12-14 15:40:09] |
Sierra_Chart Engineering - Posts: 17267 |
We will check on these.
[2022-12-20 14:42:46] |
We will get these solved in the next release.
