Date/Time: Tue, 01 Apr 2025 22:07:58 +0000
Formula for check between H and L of last three bars
View Count: 523
[2022-12-14 12:14:55] |
Dean Roberts - Posts: 79 |
Hi Tom and John Could you help with the last part of this formula please? I am trying to say only enter if only enter the long if the High of the 3rd prior bar is LESS than 30 points above the Low of the bar that has just closed: =AND(CROSSFROMABOVE(C,ID15.SG3), L[-1]<=ID15.SG3[-1]+(4*TICKSIZE), H[-3],L[-1]<(120*TICKSIZE)) Not sure how to contruct the difference between the different candle Highs and Lows. Much appreciated Cad |
[2022-12-14 12:52:04] |
Sawtooth - Posts: 4189 |
Try this: =AND(CROSSFROMABOVE(C,ID15.SG3), L[-1]<=ID15.SG3[-1]+(4*TICKSIZE), H[-3]-L[-1]<(120*TICKSIZE)) |
[2022-12-14 15:44:03] |
thank you Tom.
