Date/Time: Tue, 01 Apr 2025 22:06:43 +0000
Resistance and support lines on studies, Swing Low and Swin high lines on studies
View Count: 1242
[2022-12-14 02:46:06]
Chap - Posts: 39
Hi
Is possible to add automatically Resistance and support lines on studies, Swing Low and Swing high lines on studies, for example I want to add automatically Resistance and support lines on OBV and Cumulative delta, I don't want to draw manually Support and resistance lines on these studies.
Thanks.
[2022-12-14 16:51:10]
John - SC Support - Posts: 39080
Refer to the following:
Automatic Trendlines
[2022-12-15 09:41:10]
Chap - Posts: 39
Hi.
Thanks for your reply.my question is about horizontal lines, Support and resistance lines on studies. i appreciate your help
[2022-12-15 17:15:57]
Yes, you did state that. Sorry, we did not internalize it all the way.
You can try to use the Swing High/Low study, but it is looking for the High and Low to be specifically in the SG2 and SG3 positions. So this would work for the Cumulative Delta bars, but it would not work on OBV.
The same thing is true for the Pivot Points study.
