Date/Time: Tue, 01 Apr 2025 22:05:47 +0000
Multiple Apex accounts
View Count: 991
[2022-12-13 20:58:18] |
rondawes - Posts: 39 |
I have 3 Apex evaluation accounts. When I use the first one, i.e APEX-12345-01, the trades show on the charts. But when I use either of the other two, the trades do not show up on the charts. i.e. Apex-12345-02 or -03. I'm fine with only using one a day if I need to change some setting manually.
[2022-12-13 21:17:58] |
John - SC Support - Posts: 39080 |
First of all, are all three of these accounts accessible under a single login - so you can view all three accounts from your Trade Window and select which account you are trading with from the Trade Window? If so, then the most important thing to remember is that each chart has its own Trade Window and in order to see the trades from a particular account, the trade window must be set to that account. Refer to the following: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) And also refer to the following: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-13 22:49:53] |
Yes, the list of accounts is available as in that first reference you posted above. Tomorrow, I'll try the Trade Linking posted in the second link above. Thanks
