Date/Time: Tue, 01 Apr 2025 22:06:41 +0000
Customize the draggable order labels on chart?
View Count: 451
[2022-12-13 20:35:09] |
MeowthTradez - Posts: 44 |
What is the draggable order elements on the chart called? Is there a way I can disable the ability to change quantities on it? I don't ever use that to adjust my order quantities and am tired of accidently clicking it while trying to drag orders around and having that pop up window come up.
[2022-12-13 20:58:54] |
John - SC Support - Posts: 39080 |
You can turn off the view of the Quantity in the order lines, but this still leaves the little box that can be selected to change the quantity, although it is a bit smaller (hence slightly harder to hit accidentally). There is not a way to remove it completely. To remove the quantity number in the display on the order line, refer to the following: Global Trade Settings Windows: Order Quantity (Global Settings >> Chart Trade Settings >> Working Orders >> Working Orders - Display) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
