Date/Time: Tue, 01 Apr 2025 22:06:43 +0000
Watchlists Won't Rollover When Clicking Rollover Expired Symbols
View Count: 508
[2022-12-13 20:22:51] |
User624595 - Posts: 242 |
For example today volume on ES has rolled to March 2023 since yesterday, but clicking Rollover Expired in Watchlists still does not roll them over. The same often happens with other symbols like currency futures, etc.
[2022-12-14 18:43:23] |
Sierra_Chart Engineering - Posts: 19040 |
We will check on this and see what the issue is.
[2022-12-15 19:35:04] |
The rollover will not work, unless to symbol is completely expired.
[2022-12-16 14:28:02] |
The charts give the rollover notice, and then can be manually rolled over, but the watchlists still don't update. Going through the watchlist then switches the chart back to the old symbol again, even after rolling over the chart. After each chart is rolled over, each symbol in each watchlist, still needs to be manually rolled symbol by symbol, in each instance of SierraChart, it is repetitive and tedious. Is there any way to make this process automated? Also when clicking on the notification to roll each chart, the dialog defaults to the existing expired symbol rather than the next contract. Date Time Of Last Edit: 2023-01-05 03:21:49
