Date/Time: Tue, 01 Apr 2025 22:07:57 +0000
How to active software with Gain futures
View Count: 524
[2022-12-13 16:22:52]
User684537 - Posts: 3
How would l download version 2416 for use with Gain futures?
Thank you
Marv
[2022-12-13 16:36:48]
Sierra_Chart Engineering - Posts: 19040
Follow the instructions here:
Software Download: Full Control Rollback Procedure
We also activated your Sierra Chart account for two weeks so you can do testing.
[2022-12-15 09:06:59]
Thanks for the help... l now have version 2416 installed.
l followed all the instructions in the GAIN futures site, but l still cannot connect Sierra with GAIN.
l get the message attached below.
What am l missing?
Marv
imageNo GAIN.jpg / V - Attached On 2022-12-15 09:03:03 UTC - Size: 54.06 KB - 91 views
imageNo GAIN.jpg / V - Attached On 2022-12-15 09:04:10 UTC - Size: 54.06 KB - 92 views
[2022-12-15 17:05:14]
John - SC Support - Posts: 39080
We have changed your account from being on a Trial to being on Package 11 for the same time. We do not allow for external connectivity during a trial, which is why you were getting the message. You should be fine now, but it is best to Exit from Sierra Chart and restart to ensure your local copy picks up the change.
