Date/Time: Tue, 01 Apr 2025 22:06:44 +0000
probleme de flux avec leurex
View Count: 320
[2022-12-13 16:11:34] |
tunesirodolfo - Posts: 5 |
bonjour j'ai un problème avec mon flux eurex hier tout allais bien et aujourd'hui cela ne fonctionne plus et j'ai un message d'erreur qui s'affiche merci de me donner la solution a mon problème |
[2022-12-13 17:26:07] |
John - SC Support - Posts: 39080 |
From Google Translate: hello I have a problem with my eurex feed yesterday everything was fine and today it no longer works and I have an error message that appears
thank you for giving me the solution to my problem You have the EUREX exchange setup for your account, so you should be getting the Eurex data without any issue. What exactly is the error message you are receiving? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
