Date/Time: Tue, 01 Apr 2025 22:06:44 +0000
Denali Feed Eurex Depth Error & Tick Size Swiss Franc Future CME
View Count: 399
[2022-12-13 14:03:36] |
User525997 - Posts: 20 |
Please check the market depth for the Eurex Symbol GBM-202303-EUREX (BOBL Future). The market depth(bid and ask) is overlapping, which is an error. In addition I noticed a problem with the Swiss franc contract at the CME CHF-202212-CME. I think there is an issue with the tick size. Thank You. |
[2022-12-13 16:40:50] |
John - SC Support - Posts: 39080 |
With regards to the overlap of the Bid/Ask, refer to the response here: DOM error - bids and offers overlap With regards to the Swiss Franc, the Tick Size should be 0.00005 per the CME website: https://www.cmegroup.com/markets/fx/g10/swiss-franc.contractSpecs.html What exactly are you seeing? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
