Date/Time: Tue, 01 Apr 2025 22:04:45 +0000
target reset and custom target from trade window
View Count: 411
[2022-12-13 12:31:15] |
User181801 - Posts: 42 |
Hello and thanks for your help, I am contacting you for 2 reasons: 1. I select my target ticks and stop ticks from the "Targets" tab in the trade window. Once I change the selection from the dropdown above -for example if I go from "2Targetswithcommonstop" to "simplebracket"- and return back my target and stop ticks have reset and I need to re-enter my preferred ticks. Is there a way to avoid that? 2. Can I build custom configurations, name them and make them appear in the trade window dropdown menu? If yes, could you point me to a link with instructions? thanks again |
[2022-12-13 16:22:41] |
John - SC Support - Posts: 39080 |
1. You need to not change the Configuration selection at the top. Or you need to save the configuration when you have made changes to it. When you select a Trade Configuration, it is going to change your orders to what has been saved with the configuration. Refer to the following: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations 2. See above. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
