Date/Time: Tue, 18 Feb 2025 22:06:29 +0000
Saving Spreadsheet changes
View Count: 375
[2022-12-13 11:25:21]
User299107 - Posts: 58
HI,
I've recently added new formulas to the spreadsheet - saved it - minimized the SS - but when I maximize it, the new formulas have gone.
Can someone shed some light on this please
thanks,
Eliza
[2022-12-13 16:18:08]
John - SC Support - Posts: 38029
Make sure you have the correct sheet selected and that it did not change when you minimized/maximized (it should not have, but check this).
If you are using a Spreadsheet Study, then check to see if the "Formula Source Sheet" in the Inputs for the Spreadsheet Study is set to a different number than the Chart number. Also, at the top of the sheet at D1 is the information for the Formula Source Sheet, you can check that as well to make sure it is set to be the same sheet as the one that is pulled up at that time. Refer to the following for more information on Formula Sheets:
Spreadsheet Study Inputs: Formula Source Sheet Number
[2022-12-13 20:08:54]
I have checked the Sheet number and it is consistent with the chart no.
However, I notice that the Spreadsheet doesn't autofill down the column after entering the formula, and again, it failed to save after minimizing.
Am I missing something?
Eliza
[2022-12-13 20:48:47]
sorted - I was using the wrong sheet
