Date/Time: Fri, 18 Apr 2025 18:58:43 +0000
vertical IBR for simple barchart
View Count: 589
[2022-12-12 22:26:18]
MarcOh - Posts: 171
Is there any opportunity/drawing style to highlight a leftside vertical IBR ? Used the search function already.
thx in advance
imageScreenshot_1.png / V - Attached On 2022-12-12 22:26:11 UTC - Size: 87.68 KB - 117 views
[2022-12-13 15:41:33]
John - SC Support - Posts: 39357
Refer to the pair of draw styles at the following link:
Chart Studies: Left Offset Box Top for Candlestick (ACSIL: DRAWSTYLE_LEFT_OFFSET_BOX_TOP_FOR_CANDLESTICK) and Left Offset Box Bottom for Candlestick (ACSIL: DRAWSTYLE_LEFT_OFFSET_BOX_BOTTOM_FOR_CANDLESTICK)
[2023-01-21 06:47:51]
MarcOh - Posts: 171
hey john,
thats the result, which, frankly, is pretty depressing. what am i missing?
imageScreenshot_1.png / V - Attached On 2023-01-21 06:47:47 UTC - Size: 26.14 KB - 106 views
[2023-01-22 09:06:34]
Sierra_Chart Engineering - Posts: 19269
There is no support for what you want to do. It does not exist unless you use a TPO Profile Chart.
Date Time Of Last Edit: 2023-01-22 09:06:48
