Date/Time: Tue, 01 Apr 2025 22:04:45 +0000
Any Update on AMP and Teton?
View Count: 749
[2022-12-12 21:17:58]
ondafringe - Posts: 320
Last thing I read on here was you expected AMP to support Teton by the end of October.
A month and a half later and still haven't seen/heard anything from AMP indicating support.
Been waiting for over a year, and just wondered if you have an update on how much longer before this comes about?
Thanks.
[2022-12-13 12:45:43]
Sierra_Chart Engineering - Posts: 19040
We should not be giving any estimates about this. This is not within our control. Based upon what we see AMP is moving very slowly on this.
At the rate it is going, they may not support Teton until the middle of 2023.
[2022-12-13 13:48:23]
Okay, I appreciate the update, but won't ask again. I'll just wait it out.
[2022-12-15 14:53:32]
Just to update this:
I asked AMP about this in another forum and they indicated they will support Teton... very soon, whatever that means. :)
[2022-12-15 15:06:31]
We doubt very much it will be very soon.
That would have to translate to several months from now. If even that.
Date Time Of Last Edit: 2022-12-15 15:06:45
[2022-12-16 15:07:03]
Edge Clear - Posts: 17
@ondafringe,
Have you considered talking to someone on our team? We are a launch partner for Sierra Chart Teton and can work on a solution for you. When you need answers, you will not have to ask in a forum because you will be assigned a personal broker for whatever you need.
Consider getting Teton right away here: https://edgeclear.com/sierrachart or please get in touch with us by calling us at 773-832-8320 / 1-844-872-3320 (US and Canada only).
We look forward to welcoming you as a Sierra Chart user and a new member of Edge Clear or pointing you in the right direction.
Edge Clear LLC
Innovative. Transparent. Trader-Inspired.
Derivatives trading is not suitable for all investors. Past performance is not necessarily indicative of future results.
[2022-12-16 15:55:59]
Thanks, but I'm good.
