Date/Time: Tue, 01 Apr 2025 22:10:39 +0000
Comissions on trades
View Count: 1446
[2022-12-12 20:08:41] |
OriolCasas - Posts: 189 |
Hello, I am using a Journal outside Sierra (edgewonk, which has nothing to do with you I know) but I would like that the trades I import count the comissions. Which currently they dont. My account is Live. And I don't find a way to add the comissions. How can that be done? Thank you |
[2022-12-12 21:09:50] |
John - SC Support - Posts: 39080 |
We can only tell you how to add commissions within Sierra Chart. Whether that carries over to Edgewonk - we do not know. The information for having commissions show up in your Trade Activity Log is at the following link: Trade Activity Log: Use Commission For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-12 22:08:23] |
Ok that's what I was looking for, but now I find out that when I go to global settings, symbol settings I can't use different comission for different products, how is this possible? Thank you |
[2022-12-13 15:25:14] |
You can set the Global commission or you can set it per symbol. To set it per symbol, select the symbol under Global Symbol Settings and find the entry for "Round Turn Commission". Enter the value for that symbol and then that will be used in the Trade Activity Log.
