Date/Time: Sat, 30 Nov 2024 05:48:26 +0000
Volume Based Roll Over
View Count: 503
[2022-12-12 18:37:44] |
User841161 - Posts: 221 |
Changed the chart setting for VX contract to Continuous Futures Contract-Volume Based Roll, Automatically Rollover Futures Symbol-Yes. Why is it not auto rolling, still asking to rollover
12-13-22.png / V - Attached On 2022-12-12 18:37:32 UTC - Size: 185.64 KB - 71 views |
[2022-12-12 19:07:13] |
The Automatically Rollover Futures Symbol does not work with Volume based rollover. It only works on the date rollover. Refer to the following: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
