Date/Time: Sat, 30 Nov 2024 06:41:18 +0000
Cycle_Period Spreadhsheet Help
View Count: 266
[2022-12-12 16:38:32] |
User763002 - Posts: 27 |
Hello, I am looking to see if I can get some assistance using the Cycle Period spreadsheet. I have downloaded it and changed the symbol to match what is active in the SC chartbook but I am getting no response for the sheet. I am sure I am doing something wrong but Have not found an answer on the support board. Thanks |
[2022-12-12 18:42:47] |
If that is a Spreadsheet Study then you would need to connect it to the study itself by changing the Spreadsheet Name in the Spreadsheet Study to bring in that specific spreadsheet. Refer to the following: Chart Studies: Settings and Inputs Tab >> Spreadsheet Name / DLL File and Function Name Otherwise, we recommend contacting whomever you received that spreadsheet from to see if they can help you. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
