Date/Time: Sun, 20 Sep 2026 09:43:55 +0000
[Programming Help] - Formula to check if price has been above a level for X minutes.
View Count: 704
[2022-12-12 11:43:49]
Dean Roberts - Posts: 79
Hi
I'm trying to add a simple formula to go long if price has been above a level for x number of minutes... a simple pull back long basically.
Would this work - with AS being the level I am trying to do the check for price being above for 8 minutes (if this was a minute chart)?
AND(CROSSFROMABOVE(C3:C1000,AS3:AS1000), C3[-1]:C1000[-1]>AS3[-1]:AS1000[-1], C3[-2]:C1000[-2]>AS3[-2]:AS1000[-2], C3[-3]:C1000[-3]>AS3[-3]:AS1000[-3], C3[-4]:C1000[-4]>AS3[-4]:AS1000[-4], C3[-5]:C1000[-5]>AS3[-5]:AS1000[-5], C3[-6]:C1000[-6]>AS3[-6]:AS1000[-6], C3[-7]:C1000[-]>AS3[-7]:AS1000[-7], C3[-8]:C1000[-8]>AS3[-8]:AS1000[-8])
Is there a way of adding in a check to say price was a certain number of points above the level for that time period?
Much appreciated
Cad
[2023-01-06 19:44:29]
ForgivingComputers.com - Posts: 1238
One approach would be a spreadsheet study and a formula that adds one to the previous value if the condition is true, and resets it to 0 if false.
Assume:
E3 = Last
AS = ID1.SG1
New Formula 1
Price above AS:
P3 =(E3>ID1.SG1@3)
New Formula 2
Count of Bars with Price Above AS:
O3 =if(P3,O4+1,0)
New Formula 3
Buy Entry - If Count >= 8 and position is flat:
K3 =AND(O3>=8,J$8=0)
