Date/Time: Sat, 30 Nov 2024 06:40:44 +0000
Rolling over from ESZ22 to ESH23 Gives displaced price
View Count: 583
[2022-12-12 10:02:12] |
Techotomy - Posts: 104 |
I'm seeing about a 30 point difference in price between 2022-12-09 and 2022-12-12 that shouldn't exist when I rolled over from ESZ22 to ESH23. How do I fix this?
[2022-12-12 13:20:22] |
seandunaway - Posts: 279 |
But March is trading about 30 pts higher than December. (:
[2022-12-12 18:10:01] |
If you do not want to see that gap, then you would need to use a Continuous Futures Contract option that has the "Back Adjustment". Refer to the following and the option after it: Continuous Futures Contract Charts: Continuous Futures Contract - Date Rule Rollover, Back Adjusted For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
