Date/Time: Sat, 30 Nov 2024 06:27:44 +0000
Gold chart
View Count: 1040
[2022-12-12 09:48:35]
User442792 - Posts: 9
Hi i use GCG23_COMEX symbol for gold, and i loaded sierra charts now, but gold charts start grom 10:23, i started sierra chart 10:33, i have 10 minute delayed data so, why does my chart start on time when i started it? last candle before 10:23 is from friday..
[2022-12-12 13:05:19]
Sierra_Chart Engineering - Posts: 17269
Follow the instructions here to re-download the data:
Also update Sierra Chart to a current version:
[2022-12-12 13:23:57]
Ok thank you that solved the CG problem, but i have another one with ES, market profile chart is showing high of 9-12(friday) around 3990 but my normal 15minute candlestick chart is showing that high of friday is around 4024, i tried to redownload data like with CG but it did nothing
[2022-12-12 15:27:00]
If it is a Continuous Futures Contract chart, then refer to:
Continuous Futures Contract Charts: Displaying Rollover Transition Times and Contract Months
You will notice a price difference when transitioning from one contract to the next.
Date Time Of Last Edit: 2022-12-12 15:27:14
[2022-12-12 16:12:58]
I did whats written on the page, but nothing changed
[2022-12-12 16:13:47]
I can see that today new futures symbol starts, but i changed it to ESH23-CME, so what should i do ?
[2022-12-12 18:38:08]
John - SC Support - Posts: 36350
If you are not using a Back-Adjusted Continuous Futures Contract option, then you should be able to see the data from last Friday as it was for that symbol (just make sure the transition from the Z contract to the H contract is where you expect it - you can turn on "Chart >> Show Rollover Dates" to see where the rollover occurs).
Another options is to load the ESZ22-CME symbol for a chart by itself and then look at the data just for it.
Otherwise, the information you are looking at has been modified, so it will not line up exactly. Refer to the information for back-adjusted rollover options here:
Continuous Futures Contract Charts: Understanding Back Adjusted Price Data and Comparisons
