Date/Time: Tue, 26 Nov 2024 17:31:11 +0000
TPO Value area lines
View Count: 1346
[2014-05-29 07:48:16] |
User54027 - Posts: 128 |
HI Support, I am happily using this indicator however would like to change its appearance on screen. I would like to see todays VA lines plotted from yesterdays calcs, however do not want to see previous days lines plotted on the chart. How can I just see the current levels and remove prior days levels? I am sure this is simple to do however I cannot find the correct settings for this! Thanks! |
[2014-05-29 22:05:41] |
Most studies including this study do not have the ability to limit the number of days they are calculated on in the chart. They are calculated across all of the data loaded in the chart. So it is not possible to do what you want.
[2014-05-29 23:44:06] |
Sawtooth - Posts: 4120 |
You can do this with the Spreadsheet Study study. Check Hide Study on the TPO study. Add the Spreadsheet Study study. -give it a name in the Spreadsheet Name field -set the colors and draw styles as follows: K(SG1) as TPO POC L(SG2) as TPO VAH M(SG3) as TPO VAL put these formulas in the respective cells: K3: =IF(O3=$O$1,AA3,0) L3: =IF(O3=$O$1,AB3,0) M3: =IF(O3=$O$1,AC3,0) O3: =IF(INT(A3)>INT(A4),O4+1,O4) O1: =MAX(O3:O1002) this assumes the TPO Value Area Lines study's outputs appear in columns AA, AB, AC. Edit the formulas as needed, or move the TPO study to the top of the Studies to Graph list. Date Time Of Last Edit: 2014-05-29 23:53:16
[2014-05-30 07:16:15] |
Many thanks Tomgilb!
