Date/Time: Sat, 30 Nov 2024 06:45:37 +0000
Recover chartbook
View Count: 300
[2022-12-11 20:04:56] |
User575399 - Posts: 322 |
I bought a new computer and login to my account but I can’t find my chart book anywhere . Even in backup folder . Any ideas ? Thanks ! |
[2022-12-12 15:37:05] |
You need to copy the Chartbooks from your other computer. Refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
