Date/Time: Sat, 30 Nov 2024 06:44:40 +0000
Copy / bridge multiples cuentas
View Count: 345
[2022-12-10 10:20:21]
User865162 - Posts: 1
Buenos días,
Dispongo de varias cuentas y me gustaría poder operar desde Sierra a la misma vez. Existe una copiadora o puente que me permita enviar una orden a varias cuentas? en este caso, sería enviar la misma orden a un broker y a una cuenta fondeada. (ahora mismo lo hago con Ninjatrader y una copiadora, puede hacerse algo parecido con Sierra?)
muchas gracias
[2022-12-12 16:29:44]
John - SC Support - Posts: 36350
From Google Translate:
I have several accounts and I would like to be able to operate from Sierra at the same time. Is there a copier or bridge that allows me to send an order to several accounts? in this case, it would be sending the same order to a broker and to a funded account. (Right now I do it with Ninjatrader and a copier, can something similar be done with Sierra?)
Thanks a lot
For what we have available in terms of copying orders, refer to the following:
Order Allocation to Trade Accounts
