Date/Time: Mon, 31 Mar 2025 08:48:11 +0000
1 minute and 5 minute VWAP are different
View Count: 550
[2022-12-09 19:41:03] |
MeowthTradez - Posts: 44 |
I just noticed VWAP is off by 2 ticks for me on the 1 minute vs the 5 minute. What's causing this and how do i fix it?
[2022-12-09 20:07:01] |
John - SC Support - Posts: 39026 |
They should be different unless you have the option for Base on Underlying Data set to Yes. Refer to the following: Volume Weighted Average Price (VWAP) with Standard Deviation Lines: Differences Between VWAP and Standard Deviation Lines On Different Timeframe Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
