Date/Time: Mon, 31 Mar 2025 08:45:31 +0000
Line opacity
View Count: 1003
[2022-12-08 22:30:15]
User575399 - Posts: 326
Is their a way to adjust the line drawing tool opacity?
It covers up important info on my chart and makes it difficult to see. Thanks
[2022-12-08 23:02:23]
John - SC Support - Posts: 39026
There is not an option for a Transparent Line. Transparencies in general, create a lot of overhead and make the graphics very sluggish.
But, there are options for where the drawings are placed - either above or below the main price graph. Refer the following setting and the one before it:
Chart Settings: Draw Highlight Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu)
[2022-12-09 00:38:38]
Then why is it possible on a extended rectangle to change the inside opacity ?
[2022-12-09 14:03:59]
We did set up some of the drawings to have it, but lines do not.
[2022-12-09 16:58:11]
What drawings ( besides rectangle) have it?
Man , that would be awesome if you guys could add that! 😉
[2022-12-09 18:08:29]
Just what are called the "Highlight" drawings have the transparency option. These are the Rectangle | Extending Rectangle | Ellipse | Triangle.
