Date/Time: Mon, 31 Mar 2025 08:45:30 +0000
Study/System with input Symbol X & Execution on Symbol Y?
View Count: 323
[2022-12-08 22:25:10] |
User500500 - Posts: 16 |
Does Sierra Chart allow the automation of a strategy to be using price movement of Symbol X to create signals executed on Symbol Y? Normally, I would easily get input & execute output on same Symbol X but this is the only work around I can think about to compensate for the issue of SR3 on CQG with Denali* having a 'market data' symbol different than the 'execution' symbol. * Refer to: Missing CME symbols in Exchange Data Feed Open to any other approach, Thanks |
[2022-12-08 22:59:30] |
John - SC Support - Posts: 39026 |
Refer to the following: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
