Date/Time: Mon, 31 Mar 2025 08:45:31 +0000
Is cpp file available for Initial balance study?
View Count: 398
[2022-12-08 19:07:58]
User581888 - Posts: 11
Hi, just would like to modify it for my personal use. If the source code available for the Initial Balance study, where do I find it? Thanks
[2022-12-08 19:32:45]
John - SC Support - Posts: 39026
In general, refer to the following for how to find the source code for the available studies:
How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies
In this particular case, the code is in the file Studies6.cpp.
[2022-12-09 17:50:05]
JohnR - User831573 - Posts: 325
It is in Studies6.cpp
I use NotePad++ as a secondary editing tool while using VS2022 as my main tool. A capability of NotePad++ is the ability to search for text within a file, file type, directory, etc. This is really useful as I look for instances of code or structure/property/variable definitions in .cpp or .h files within my development dir or SierraChart\ACS_Source
Hope this helps
JohnR
Date Time Of Last Edit: 2022-12-09 17:50:35
imageSC_Forum_Reply_Find Code.jpg / V - Attached On 2022-12-09 17:49:53 UTC - Size: 88.08 KB - 86 views
