Date/Time: Sat, 30 Nov 2024 06:43:27 +0000
Market Replay and back test question
View Count: 353
[2022-12-08 18:40:35] |
User887126 - Posts: 66 |
Hello SC team, Regarding Market Replay: 1. Is there a way i can replay my previous trades? Tradovate has this function and was wondering if SC has this also. 2. Can I jump from trades to trades during market replay? For Example: i have 100 trades for previous day and i want to review trade #13 and #56 only for that day. I want to be able to just type in trade/order reference number and jump there directly. Is it possible? Regarding BackTest: Is there a built-in function in SC to automate (simultaneous or loop) backtest? For example, i want to try different numbers in particular parameter that i am working with and simultaneously test them (it could be 10 , 20 or even 100). Do you have a function i can use to do that or i need to write my own ASCIL for this? It gets very tedious to manually open different instances, chart books, change parameter and backtest them. Thank you in advance. Date Time Of Last Edit: 2022-12-08 18:41:14
[2022-12-12 14:58:05] |
Sierra_Chart Engineering - Posts: 17271 |
1. Yes. Refer to: Replaying Charts: Replaying Non-Simulated / Live Order Fills 2. You can jump forward during a replay: Replaying Charts: Jump When the fills are visible on the chart you can move forward and backward through them: Trade Menu: Goto Next Chart Fill (Trade menu) For back testing refer to: Auto Trade System Back Testing There is no functionality to do simultaneous back ttesting, and automatically change study Input parameters. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-12 14:59:22
