Date/Time: Mon, 31 Mar 2025 05:29:55 +0000
Any way to not print prior market depth historical graph levels for a cleaner chart
View Count: 317
[2022-12-08 15:48:31] |
User279510 - Posts: 17 |
Running MDHG on charts. When there is a lot of activity, often on a single bar, it creates a very cluttered chart. Is there any way to show only active levels and not historical levels? Thanks.
[2022-12-08 16:52:40] |
John - SC Support - Posts: 39026 |
Set the following setting to a value of 0 and the Market Depth Historical Graph will only show what accumulates from that point forward: Chart Settings: Maximum Market Depth Data Days to Load (Chart >> Chart Settings >> Market Depth menu) If you select Chart >> Reload and Recalculate then the data will reset back to just the current bar (but will again accumulate from there). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
