Date/Time: Mon, 31 Mar 2025 05:11:18 +0000
absolute value
View Count: 710
[2022-12-07 21:10:43]
User970210 - Posts: 100
does sc has function for absolute value for alert condition, like abs(id1.sg1-id1.sg1[-1])? thx
[2022-12-07 23:10:03]
John - SC Support - Posts: 39026
The function ABS() gives the absolute value of an item and works with Alerts.
Some of the spreadsheet functions also work in Alerts. The easiest way to test is to put the function into the Spreadsheet Formula, as this study uses the Alert syntax. For example - to test if this worked, I entered =ABS(-1) in the Spreadsheet formula and the result is a line at the value of 1. Therefore, it can be used in Alerts.
