Date/Time: Mon, 31 Mar 2025 05:21:10 +0000
Disable dragging the lines from open orders possible?
View Count: 354
[2022-12-07 20:58:41] |
MeowthTradez - Posts: 44 |
With open orders there is the label to the left with your order details and then a line extended all the way through the entire chart to the right. Is there a way to disable being able to drag that line and make the label draggable only? I find myself dragging the line on accident sometimes trying to move the chart around and instead filling orders I didn't want to and losing out of profits.
Date Time Of Last Edit: 2022-12-07 20:59:50
[2022-12-07 22:34:28] |
John - SC Support - Posts: 39026 |
There is not a way to make the line not modify the order. But there are a few options. Make the line as thin as possible. Go to Graphics Settings and change the Width for the items associated with the lines (such as "Chart Trading Order Line Buy Limit") to a value of 1. Push the order information boxes to the right. Refer to the following setting and the 2 after it: Chart Settings: Align Order Cancel (X) Button to Right (Chart >> Chart Settings >> Trading menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
