Date/Time: Mon, 31 Mar 2025 05:21:11 +0000
How to remove Stop and Target modification confirmation
View Count: 789
[2022-12-07 20:34:44] |
Alejandro Prado - Posts: 1 |
Hi, I need help removing the Confirm Order message that pops up when I adjust my Stop or Target. I've made sure the Confirm Order Modifications is Unchecked. I would like to schedule a phone and Remote assist session with your support. 0.75 USD/minute Feel free to call or email me with the next step. Phone (561) 929-2646 alexjoat@yahoo.com Thank you, Alex Prado |
Attachment Deleted. ![]() |
[2022-12-07 22:22:55] |
John - SC Support - Posts: 39026 |
You can turn off the notifications for Modifications by ensuring the option on the Trade Window for Trade Window >> M >> Confirmations >> Confirm Order Modifications is not enabled (unchecked). Refer to the following documentation for this: Basic Trading and the Trade Window: Main/C >> Menu > > Confirmations >> Confirm Order Modifications (chart specific) Also note the other order confirmation options in that same section. Additionally, you would need to make that change for each chart to turn off the confirmations. If you want to turn off all confirmations for all charts, then there is the global option at Trade >> Chart Trade Settings >> General >> Disable Order Confirmations - Global. Refer to the following: Global Trade Settings Windows: Disable Order Confirmations - Global (Global Settings >> Chart Trade Settings >> General >> Confirmations) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
