Date/Time: Mon, 31 Mar 2025 08:48:11 +0000
question
View Count: 414
[2022-12-07 18:50:02] |
User427561 - Posts: 217 |
isthere a way to attach cross hairs to the movemen of a bar on the chat and if so how to do it?
[2022-12-07 21:58:32] |
John - SC Support - Posts: 39026 |
If we are understanding what you want, then the only way to do this would be to put a Vertical Line and a Horizontal Line at the bar in question.
[2022-12-08 12:52:54] |
thanks I know that. I was wondering if we could attach these crosshairs to the bar on the chart so as they move simultaneously with the bar on the chart
Date Time Of Last Edit: 2022-12-08 12:55:47
[2022-12-08 14:16:44] |
No, there is not a way to attach crosshairs to a bar and have it move with the bar apart from what we gave previously to use drawings.
[2022-12-09 21:54:48] |
but the movement of the bar itself is shownn on the vertal scale(tho very faintly) and was wondering if we could attah crocss hairs to those indications
Date Time Of Last Edit: 2022-12-09 21:58:22
[2022-12-09 22:09:56] |
There is the Current Price Line study, which sounds like it may be some of what you are looking for. Refer to the following: Current Price Line For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
