Date/Time: Mon, 31 Mar 2025 05:26:50 +0000
cancelling the depth storage
View Count: 331
[2022-12-07 18:35:32]
User61576 - Posts: 445
i have a sub instance which i would like to stop saving it's data (sc folder\data\depth) and i read how to turn it on though i could not turn it off
the settings in symbol settings are off and yet it saves depth
pls advice
imageScreenshot_15.jpg / V - Attached On 2022-12-07 18:35:11 UTC - Size: 116.39 KB - 95 views
[2022-12-07 21:49:13]
John - SC Support - Posts: 39026
You would also need to make sure you do not have the option for Global Settings >> Symbol Settings >> Use These Symbol Settings in New Instances when Started enabled in the Main Instance of Sierra Chart. If you change this, you will want to exit all Sub-Instances and start again to ensure that the symbol settings are not being overwritten.
Also, you have to ensure you do not have the Market Depth Historical Graph on any of the charts in the Sub-Instance, as having this study on a chart will force the saving of the Market Depth as well.
