Date/Time: Tue, 01 Apr 2025 22:05:46 +0000
TPO historical data
View Count: 659
[2022-12-07 18:34:47] |
User411320 - Posts: 312 |
how can I get data past 11/7/22?
[2022-12-07 21:40:10] |
John - SC Support - Posts: 39080 |
Refer to the following: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-12 21:04:55] |
hello, I've dowwnloaded and deleted the data, rolled over and im in a continues chart and it's not helping |
[2022-12-12 21:47:57] |
Please give us a screenshot of what you are seeing. Refer to the following for how to post a screenshot: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-12 22:11:59] |
attached
[2022-12-13 15:31:02] |
How many days do you have set for Chart >> Chart Settings >> Data Limiting >> Days to Load for Intraday Chart Type? Or, if you are using a Date Range, what is your Date Range From set to? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-15 22:15:48] |
thanks,that worked. how can i do a weekly TPO?
[2022-12-16 15:17:48] |
Set the following Inputs on the TPO study: - Profile Time Period Length: 1 - Profile Time Period Length Unit: Weeks Set the other Inputs as needed. Refer to the information starting at the following link: Time Price Opportunity (TPO) Profile Charts: Profile Time Period Length For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
