Date/Time: Mon, 31 Mar 2025 05:26:51 +0000
CHT-File is not loaded in the Sierra chart
View Count: 811
[2022-12-07 18:18:19] |
Remo Schwager - Posts: 1 |
hello guys I have a CHT file that won't load. I have saved them in the Data folders, but nothing is displayed under Analysis in the Sierra Chart? Does somebody has any idea? I have attached the files. |
Attachment Deleted. ![]() Private File |
[2022-12-07 21:38:55] |
John - SC Support - Posts: 39026 |
A .Cht file is a Chartbook. You need to put this file in the Data folder and then open it using File >> Open Chartbook. This is not a DLL file that contains a study. We do not use a .cst file extension, so that is from some other program. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
