Date/Time: Sat, 30 Nov 2024 06:29:52 +0000
Always On Top
View Count: 649
[2022-12-07 17:31:01] |
rondawes - Posts: 39 |
I have 2 small windows that are Detached that I'd like to be always on top, i.e. always visible above other windows. The Always On Top on the Window menu is always grayed out. I've searched here and googled and have not found how to enable this. Thanks
[2022-12-07 21:19:31] |
What windows are these? Are these detached charts? Or something else (like Time and Sales or Market Depth, etc.)?
[2022-12-07 22:28:14] |
They are charts.
[2022-12-07 23:23:33] |
It sounds like you are selecting the Window menu on the main Sierra Chart software. When a window is "Detached" then that menu no longer applies. Rather, you need to select the Window menu on the specific chart. If you have turned off the menu for those detached charts, then you would need to turn it on again in order to select the Window >> Always on Top. Refer to the following for how to access the menu for a detached chart if it is not showing: Chart Menu: Show Menu (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-08 15:32:28] |
Thanks!
[2022-12-10 19:57:59] |
User146848 - Posts: 121 |
Is there a way to move The T&S window around with the instance window like any other chart window (Pin down/Dock the T$S window )?
[2022-12-12 16:40:18] |
The T&S window is not "dockable" it is a separate window and is always "floating" as it does.
[2022-12-12 16:51:40] |
Yes, are there technical reasons? It doesnt makes sense not to have at least a docking option.
