Date/Time: Mon, 31 Mar 2025 05:24:30 +0000
Symbol missing or naming change
View Count: 317
[2022-12-07 15:14:55]
Chris_Janowski - Posts: 6
My Sierra account is connected with IB, works fine. I need to use the charts of the following symbols: 6EZ22_FUT_CME / 6AZ22_FUT_CME / CLF23_FUT_CME / GCG23_FUT_CME / YMZ22_FUT_CME but I can not find them in the symbols given. How can I find the correct charts?
Please help.
greetings,
[2022-12-07 18:29:42]
John - SC Support - Posts: 39026
Those particular symbols are for when Sierra Chart is connected to our direct Teton Order Routing service, or our Trading Evaluator service. They will not work with IB.
If you already have charts with those symbols on them, then open your Chartbooks and select Edit >> Translate Symbols to Current Service. This will change the symbols to what is needed for your Current Selected Service.
If you do not already have charts with those symbols, then open a new chart using File >> Find Symbol. As long as you are connected to IB in your Data/Trade Service Settings, then you will see the IB symbols in the list.
